Topic: ecu question (Read 2465 times) previous topic - next topic
ecu question
Will a Mustang 5peed ecu work on a car with an automatic?
I own an 86 5speed gt but I want to put the engine in my 88 TBird Sport and keep it auto. The car will also remain s/d . The engine is in better condition than the SO in my TBIRD.
                        :birdsmily:
Re: ecu question
Yup the 'puter is dumb on the 5.0 Stang and our Birds/Cougs... It has no idea what tranny is in the car.....
Re: ecu question
Thanks For The Info Turbocoupe50
                        :birdsmily:
Re: ecu question
With speed density i could say definetly but with mass air i've heard all kinds of stories about stalling when coming to a light and other idle problems due to the stick computer not richining the mixture enough to compensate for the fluid lag of the auto.
Re: ecu question
Maybe the 5spd is a better option , thanks
                        :birdsmily:
Re: ecu question
Quote from: 88foxt
The Bird would be more fun with the 5 speed, but IF the stick puter caused problems(I seriously doubt it) auto versons of the SD are dirt cheap..
I believe the reported stalling problems are due to the speed sensor not being installed, and/or connected. It will keep the idle speed up about 300 rpms untill the car completely stops... I've run a A9L 5 speed Mass Air processor in my Bird and it seemed the same as the A9P I normally use... I have my idle speed set at 950 in gear because of my slightly grumpy cam, so maybe thats why I didn't have a problem...
