Topic: need help (Read 2456 times) previous topic - next topic
need help
i put a cd player in my car and im geting the reave of the motor on the player dose any one know why?
88 5.0L aod with duel flowmaster and speedo mod
88 5.0L H.O with 5 speed R.I.P
87 3.8L no trans. geting h.o and 5speed (project never ending thunder) started it as of 8-14-10
96 bronco xl 5.0L 5 speed man4x4
:birdsmily:
need help
Your getting what??
need help
Do you mean electrical interferance?Did you wire it straight into the harness,or did you use the two plug installation kit (If you didn't use the kit,you should have)?
need help
That is the charging system you are hearing(alternator). You can either put a noise filter on there from like radio shack, or do as vinnie says.  I used to have that on a jeep i had, you could hear the change all the way through the gears.
brian
need help
how much do the fillters cost
:birdsmily:
need help
Hmmm....I don't know anymore. It has been a looooOOOOooong time since I owned that jeep. But I would bet not over 15 bucks or so. All you do is splice it in the power to your radio and it helps with the charging noise problem. Just go to the shack and ask, they "should" know what you are talking about.
brian
need help
ok thx
:birdsmily:
