Topic: Fila Progress Thread ( reviesed and minus all the BS) 56K death (Read 7944 times) previous topic - next topic
Ok, I'll start this off by saying this. This is a progress thread. Not some bs like the last one. If I wash the car, it doesn't make it on here. No " guess what I thought of" , no random thoughts. Only phycical work. If you have a problem with something I do, please don't trash the entire thread because of it. Oppions and ideas are fine but please, no personal stabs or any " why did you do that to the car...." stuff. With that, I give you a few progress pics of the last week or so:
Painted a carb to get an idea or two
Colors are Gloss allumnium and Flat black
The valve cover project
Painted and cleaned up brackets, timing cover for new timing chain install:
And finished project thus far:
Also done but not shown:
Dropped fuel tank
Removed intank pump
Ran new fuel line up driver side
Mechanical fuel pump
Removed all old fuel line
Started to paint underhood but ran out of paint for the day
Started to wire relay for E fan but ran out of light/got cold outside
P.S.
If you can see/guess what I did to the air cleaner lid, I'll give a free rep out of it;)
what are those valve covers off of?
1987 TC
looking better man!
Quote from: HAVI;175846
84-85 Mustang. part number E4ZE. I only did a quick sanding, some steel woll, flat black paint then sanded the fins to give it a FRPP valve cover look
Coming along.....Clean the engine bay!
Nice work.Take your time and do things right the first time.
Nice improvement Fila.................Now thats progress.
As soon as I get more paint, the engine compartment will be a solid coat of flat black. Cleaned, scrubbed then painted. Tomorow I hope to also get the rest of the fuel lines done and the E fan in and functioning
That is a great improvement. But I think you should give me that car while you are in basic training. ;)
brian
Hey, you can take it if you come get it and you work on it:flip:
Ok, with alittle help from Jacssity this is what we came up with for a realy for an E fan. It's the fuel pump realy from my car.
looks good man hows it run with the carb? . im so jelious of you and those covers i wanted to run them for YEARS! but had a v6 and then when i got the stang couldnt find them.  you could polish up the fins a little more to make them pop. but a most deff improvment man
also you know what helps clean up the engine bay alot is the rubber dizzy covers.
That's starting to look like a nice engine, Mikey. Good work.
Thanks for the comments guys!!!
As for the valve covers, all I did so far was paint them, skuff the paint on the fins and hit them quick with a nice bit of clear coat. Enough to keep them safe for not but not enough where I can never go back and sane to pollish up.
If you think this is good, I got more coming. Like hiding wiring, cleanin up all the connecters.... lots of little stuff that will add up
