Topic: Problem with TC (Read 1590 times) previous topic - next topic
Problem with TC
I have been getting a strange boost issue lately, from cold start up it seems fine under full throttle but once it is at operating temperature and you put your foot into it at about
15-17psi it has a rapid backfire/stumbling noise and the power is greatly decreased. Boost leak? that is my first guess anyways, but if it is why doesn't it stumble at 10-14psi?
I replaced the stock FPR with an aftermarket adjustable one set at 35-36ish for now (which is stock to my knowledge) which seemed to help a bit. this
 fall/winter the engines coming out and it will be getting a full go threw, all seals replaced and while it's out I am thinking about putting in a range roller
 set-up, 3" DP And ill port and polish the Exhaust Manifold as well as the upper and lower intake and use a whole lot of engine degreaser to clean it all up.
Anyways if anyone has any ideas or suggestions or has dealt with a problem like this before i would like to hear from you, cause this is g me off.
:birdsmily:
Problem with TC
I bet you're blowing out the spark on your plugs. I had the same issue at one point.
Check your gap.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Problem with TC
I had a similar effect when my intake tubing between the VAM and the turbo was sucking shut.
Problem with TC
check vam hose
check plug gap
set your fuel pressure to 40 with the vac referance off.
Go on a drive with the fuel pressure gauge conneceted aznd verify F/P rises 1:1 with boost.
Problem with TC
Quote from: SLEEPER T-BIRD 87;175968
check vam hose
check plug gap
yep.
87 thunderbird turbocoupe
06 pontiac g6 gt
:birdsmily:
Problem with TC
check vam hose
check plug gap
Thanks for the help guys especially sleeper. I have a video of what it sounds like under power from the outside after i pull away from doing a burnout, you can here it in second gear then i let off fast, its a strange sound but sounds like I might need to bump my fuel pressure up and check my spark plug gap.
heres video.
http://www.youtube.com/watch?v=q0QT7Pyme6g
:birdsmily:
Problem with TC
Yea, thats def not the vam hose... I'd check those gaps..
Problem with TC
sounds lean
