Topic: Playin with the DD (Read 2102 times) previous topic - next topic
Playin with the DD
As any good car owner I feel the need to make improvements even though this is the DD car and it only cost me $200 not including the work I did to put it on the road. So I read about the CAI for the 94 Cougar 4.6L and they want lots of money for there  I say. So I set out to make my own. To start of the factory part is Huge and doesn't flow very good. Here is a pic to give you and Idea.
So that had to go. I went and bought some supplies and worked it out. so here we go.
Now the car takes off way better. It sounds like a V8! What do you guys think? It only cost me about $30. I removed the air silencer before this.
Playin with the DD
Hmmm.. I don't think it looks to bad. Good job and way to be creative
Playin with the DD
now just get rid of the box and drop a cone K&N in the fender.
Playin with the DD
Now hack up the original tube so it will sit on top of your new intake and look stock.  That would be sweet. :)
pro-five-oh
Playin with the DD
Neat:D
Is that PCV?
Playin with the DD
Bigger MAF, bigger TB, adjustable cam gears  and a good exhaust.
Playin with the DD
Is that PCV?
Nope! I do believe that it is ABS plastic.
Playin with the DD
Quote from: thunderjet302;175775
Neat:D
Is that PCV?
Do you mean PVC or PCV;)
Playin with the DD
"PCV" is the valve for your car,"PVC" is the plastic tubing
Playin with the DD
I know, I was bein a smartass
Playin with the DD
No, you were being a postw....
Playin with the DD
Nice work. I've heard that the "violin box" intake is very restrictive, and it may have some baffle(s) inside for noise reduction. I like what you did. I got lucky with my '96, as it already had the revised intake.
Also, you may as well keep the stock air box, as it's essentially a cold air design and an aftermarket piece won't really make that much of a difference.
Be wary of the K&N filters, too. If they have too much oil on them, the wires on the MAF can become coated with the oil. This may cause the MAF wires to become built-up with poo and make the car run like butt.
Yes, I'm a wordsmith.
Quote from: V8Demon;175834
Indeed.
Playin with the DD
Quote from: ipsd;175803
Is that PCV?
Cool:D
And I meant PVC;)
Playin with the DD
Quote from: cougarcragar;175883
Never fear I have those Tamper proof torx bits and a can of that MAF cleaner. That is gonna last me for a long time. Besides I don't go crazy with the oil any way. I use the lest number of light  light coats to make a very nice even thin coat. I like to wait 30 min between coats that helps soak it all up before you add more you might not need.
