Topic: valve cover breather (Read 1034 times) previous topic - next topic
it is pulling oil into the inlet of ther turbo and burning out of the exhaust at high boost what can be done to fix it
Get the PCV vent system from Forced4 Motorsports.
1985 Thunderbird TC
2.3l .03 over,Ported and polished Head and E6 Manifold, LA3, T3/T4 Hybrid Turbo, Stinger FMIC, Forge BOV, Full 3" Exhaust, Essy Timing Gears & UDP's, BBK 255lph Fuel Pump, Kirban AFPR, Kirban Short Shifter, K&N Cone, Forced4 VC Vent Kit, PA Performance 3g Alternator, Energy Suspension Bushings throughout, CHE LCA's, SFC's [/LEFT]
Quote from: chri85tc;175346
whats their website?
Well, what is the condition of your PCV valve?  Check it.  It could be leaking under boost, thus pressurizing the crankcase...
Quote from: Chuck W;175354
how do you check them ?
Pull it out and try and blow through the small end.  NO air should pass though it.  You can clean them sometimes, but it's best just to get a new one from the dealer (USE THE MOTORCRAFT ONE ONLY) as they're cheap.
Quote from: Chuck W;175529
ok thanks
