Topic: oil pressure (Read 1047 times) previous topic - next topic
oil pressure
just curious, what does most ya"ll's oil press gauge read(non digital)at idle?
mine is rifht at the R, sound about right? no problems, just curious
thanks
oil pressure
what motor is this?
87 thunderbird turbocoupe
06 pontiac g6 gt
:birdsmily:
oil pressure
Well, My 302 runs around 40-45. I don't know about the 4 cylinders.... It would be more helpful if people knew what engine you are talking about. 4,6,or 8 cyl?
oil pressure
pointng at the R is fine.  Doesnt really matter what engine you got as loing as your not at 20psi.  any lower and lower yet with throttle applied and you have problems.
40-60 is about average for all cars out there, you cant really tell what you really have until you do a manual reading.
oil pressure
all of my 2.3t's made over 50 at idle.  my 302's make about 40 at idle.  i've never owned a 3.8 so i don't know about that one.
06 pontiac g6 gt
:birdsmily:
oil pressure
sorry guys, it is a 5.0 ll new bearings, new pump within a year ago. no noises or problems, just curious as to how much pressure i might be running?
oil pressure
Quote from: flipnbird;174897
im sure you could look up oil presure specs all day long, i can , got the books.
books dont do any good here when you rely on an electrical sub system to determin your presure.
just hook up the presure tester and read it, or buy that oil pres guage kit and use that as your tester.
no one here can possibly tell you what your oil presure is,, only a range.
oil pressure
My new 306 with standard volume oil pump has 40-45psi at idle when warm.
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
