Topic: '89 5.0 HO vs Stock SO differences (Read 1803 times) previous topic - next topic
Found the motor that I'm taking a look at this weekend and will be gathering parts for the swap over the next week. I need to know though, how is the placement of the headers' outlet compared to the stock manifolds? I assume I am going to need to drag it into an exhaust shop to have it hooked up? Any insight on this topic? I'd prefer to use the headers instead of the factory exhaust manifolds, but if the swap is done on a Saturday through the afternoon (or drags onto a Sunday), I won't be able to get it into a shop before needing it for work Monday morning.
Second, although it doesn't fit in Engine Tech, the '89 auto transmission was an aod, correct? Are there any complications with using it instead of the stock one? A different kickdown cable or anything?
Anything else I may run into along the way? I have/will have everything to convert to mass air if I don't decide to stick with speed density.
1988 Thunderbird Sport
Mark motor or mustang?  The stock exhaust for the manifolds will not bolt to stock headers..  Transmission.. only an issue baring your car column shift or console shift..
Mustang. I doubted on the headers and just thinking about using the stock manifolds until a true dual exhaust swap, whenever that may happen (still have to deal with emissions so new cats can get expensive - emissions is also one of the major reasons for the swap as this motor burns quite dirty, even though it still runs excellent and everything works as its supposed to). Full console/shifter in the Sport.
Well the mustang transmission would work just fine then, since you have a floor shifter car.  Someone here did an Ho conversion and ran through the stock exhaust. Kingcars I think.
All SEFI Stangs thru 93, used a AOD for the 5.0 auto tranny...
Yeah man, I just went through a dual exhaust swap back in May for my Sport after I did the HO conversion in March.  I had the same worries about the cats jacking up the cost of the exhaust.  Look on ebay and such for good deals.  I got a full stock Mustang H-pipe with 4 cats in good condition for $50.
The Mustang AOD has a different tailshaft governor that allows for more RPM's at WOT (about 300-400).
Quote from: V8Demon;175603
With the TV cable adjusted all the way forward my stock AOD will upshift at full throttle at 5,000 rpms. I don't know why but it does. The previous owner had the trans rebuilt about a year before I got the car but the tailshaft wasn't changed as far as I know:dunno:
