Topic: where can I find performance brake parts? (Read 3198 times) previous topic - next topic
I got the master cylinder from FLSTCI71 but the car also needs pads, rotors, and calipers. Since I need to replace all of these parts I figured I might as well replace them with the best parts I can find (or at least afford). So does anybody know where I can find a good set of four drilled and slotted rotors, steel braided lines, performance pads, and better than stock calipers?
Shazaam
Throw some Cobra brakes on the rear and call it a day.
Are you looking to retain the ABS functionality?
Well you are limited to TurboCoupe specific rotors then.
i hope not
I was going to suggest Brembo, Alcon, Wilwood......
i know brembo makes slotted and drilled stock replacement rotors. buddy bought them for his honda. price was fair also like $79 each. next time i see him i'll ask him where he got them. although it might be some time he travels alot.(drives a truck and driving instructor for skip barber school)
louie  :birdsmily:
My famous last words:
EBC sells good pads and dimpled+sloted rotors for birds and cats
Junkyard Cat
Quote from: 87cougar347;194910
Do they have a website?
The TC front rotor is larger than the regular birds. You can order an aftermarket slotted/drilled/whatever rotor for an 87-93 5.0 mustang and transfer the ABS rings from your rotors to the stang ones.
Other than the ABS ring, the 5.0 rotors are identical.
I ordered a pair of slotted/crossdrilled rotors for an 87-88 TC from Raceconcepts on the bay. They should be here Monday or Tuesday. Even if they don't have the rings, I can still swap them over. HTH.
TC#1- 2.5T- 10.14@134....9.76@138 with a 50shot
TC#2- Turbo BBF project
TC#3- parts car
