Topic: trany compatability (Read 2187 times) previous topic - next topic
trany compatability
will a AOD out of a MN-12 body t-bird/cougar fit in a fox cougar with the same type of trans.?
Re: trany compatability
yes it will.
Tc50 is using one out of a supercoupe.
thanx dominator
The shift lever was different on my SC AOD. Had to drill the hole larger and use the earlier style plastic bushing(I have the Sport floor shifter).. If you have a column shift you'll prob need to swap levers from one tranny to the other(all MN12 are floor shift).
