Topic: T-bird/Cougar SO engine performance possilities (Read 5582 times) previous topic - next topic
Re: T-bird/Cougar SO engine performance possilities
More air goin in from 1.7 roller rockers HO manifold and throttle body.... Add an adjustable fuel pressure regulator and set it 8 lbs overs stock.
Nope, threads not dead yet! I've heard rumours of a performance cam for the SO engine. Is this so, and if it is who produces it and where could one be purchased? Also what are the gains (if any) that would be experienced?
Here are two links:
http://www.cranecams.com/?show=browseParts&lvl=2&prt=5&Vehicle_Type=Auto&Cylinders=8&Engine_Make=FORD-MERCURY&Year=1987&Engine_Size=221-302%20C.I.&partNumber=364211&partType=camshaft
This one IS a hydraulic roller for 86-89 5.0 Non HO's according to crane
http://www.compcams.com/Technical/Search/CamDetails.asp?PartNumber=31-255-5
Looks like you can order this one flat tappet (for older 302's) or full roller
So i'm wondering (when am I not), if I change the heads over to e7te's and go with the proposed 1.7 roller rockers, would it make sense to change the lifters as well? I am thinking that roller lifters would be a good compliment to the rockers. However, i'm unsure what the effect/result would be. Would there be a any noticable improvement in HP over gas mileage? Also what would be a good spring match for the 1.7 rockers? Man this train of thought makes my head spin!!! :dunce:  :giggle:
You already have roller lifters:http://store.summitracing.com/default.asp?target=partdetail.asp&part=FMS%2DM6500R302&N=4294925232+4294924497+4294908331+4294892901+4294892863&autoview=sku
The 5.0 in the 86 and up birds and cats were roller blocks with rolloer cams and lifters
A Crane guy told me on the phone that the 364211 roller cam will raise the operating range of the SO engine by about 500rpm, and is designed to not confuse the stock computer.
