Topic: Brake Proportioning Valve for 88 Cougar LS 6 Cyl (Read 830 times) previous topic - next topic
Badly Needed/Wanted[/U]:
NEED Brake Proportioning Valve for my 88 Cougar.
***Please see my "UPDATE" under my original post in the "Fox T-Bird/Cougar Forums > Technical > Suspension/Steering" Secton about my brake problems called:
"Replaced Power Booster/Master Cylinder in 88 Cougar 6-banger" for the gory details and pix?
Thank you! [COLOR="Red"]@[/COLOR][COLOR="Green"]};--[/COLOR]
***AND, pleeeeeeez answer in THAT post? I'm fairly new here and am still having a bit of a prob navigating around. THX :D
are you sure that you really need a new valve?  have you tried cleaning the inside of it with brake kleen?  I'm assuming that your doing your own work... ah now I read your other posts.....    have you looked in any junk yards around KC?  I'd almost bet that the same valve was used on alot of other base model cars from the 80's mustang, thunderbird, ltd, etc.  just take a look.
Quote from: 88turbo;173983
Thanks for your response. I'm going try the yards around here, again, after this Labor Day weekend is over. ;)
I posted in here because I had absolutely NO luck with local yards a couple of weeks ago. Thx, again.
Post up a pic of what you need. I have a few here.
Jim
THX, Jim. I answered you in my Original post ;)
Quote from: thundr306;173997
Jim
See you there! :D
