Topic: Intakes (Read 1709 times) previous topic - next topic
Intakes
I'm putting my afr165's on took it apart .I have a chance to buy trickflow street heat upper +lower for a good price verses my cobra intake that I'm not to impressed with,china!.
Lookin for opinions.
Intakes
I wouldn't bother moving to a street heat intake. If it was a track heat, then I would do it. It's up to you. If you are like me, you will probably change it just to have something different.
Jim
Intakes
I though that the Trick Flow intakes were cast in China as well. The only ones that I know of that are definatly made here are the Edelbrock intakes.
Intakes
i got a holley system max2 works good but i kind of agree if it was a track heat take it but being a street heat take it if you want 2 and either way its better than stock. Also why the AFR 165s and not a set of 185s?
Intakes
Good price on them.202 in the 185's valves will probably give me pvc issues.
Intakes
The street heat does flow better by a few hp than the cobra(maybe 5hp or so) so not a huge upgrade.
However i disagree with you guys on the track heat intake and 185's.
It's to much head and intake for our cars, without a blower to fill them up the torque loss down low in our heavy cars would not be worth the time or money.
Intakes
Quote from: dominator;173781
Yeah, seems most subscribe to the old saying...
"If some's good and more is better, then too much is just right"
Intakes
Ok i got a holley system max2 e303 cam and i want 185s but i can get a set of 165s for $1000 installed if i just wait a little longer till this guy sells them and i soon may get a Paxton novi 2000 SC so i don't think it would run bad with 185s the only reason i even asked is i am not sure how soon i can get those AFR 165s.
Intakes
I was just stating that if he was looking to "upgrade", the street heat really wasn't a big upgrade, but the track heat would be.
Jim
Intakes
i would have to say if both intakes are cast in china then the trick flow is one hell of a china cast  no flaws like the cobras i have seen posted. i can post up pics if youd want bc i have the street heat off my car still in the box
Intakes
I put the cobra on for now,the motor's coming out this winter.
Alot can change by then.
Intakes
Not with the right cam and gears.  Properly tuned with a good cam and you could probably go even bigger on the heads.  Seen what GM does with the LSx motors?
