Topic: Brake Booster (Read 2482 times) previous topic - next topic
Brake Booster
Hi. I need to know which brake booster\master cyl I can use that will not hit tall valve covers on a 460. I've heard of thunderbirds using mustang ones, and mustangs using t-bird ones so i'm confused..  :dunno: Hopefully someone who's done a 460 swap can help me out.
Thanks.
Re: Brake Booster
Car Craft Jan 1992, 83 T-Bird with a 466....
By swapping a Mustang brake booster for the corresponding 'Bird part, he gained enough clearance for the driver's side valve cover.
I think our boosters are bigger, with a single diaphragm, while Mustangs use a narrower unit with dual diaphragms.
Re: Brake Booster
Thanks for the info.. Will ANY fox mustang booster work? and do you know if the valve covers were stock-style or tall?
Re: Brake Booster
1 - I don't know.
2 - This kind:
