Topic: Side Trim (Read 2048 times) previous topic - next topic
Side Trim
Ok, so I've removed my side trim, but don't know how to get the weatherstripping off.  I've tried goo-b-gone, and it doesn't work.  What have you guys used to get the sticky stuff off?
Side Trim
Spray some engine degreaser on there and let it soak in for a few then the sticky should come right off. Also you could use a plastic razor blade or a bondo filler spreader.
Side Trim
Thanks
Side Trim
eraser wheel  (avalible at most autobody supply shops)
Side Trim
I use Aero Conquest to remove vinyl racecar graphics and a small bondo-type tool called a "little chisler". The Conquest is citric oil based but washes off with water. Any residual film will wash with a mild soap and water. It will remove oil from skin and plastic, and makes a great degreaser for dirty/sludge places like from a leaking valve cover or PS pump. It isn't corrosive like purple soaps.
Side Trim
Quote from: Prototype Services;173278
Yea, That's what the goo-b-gone is, a citric oil.
Side Trim
there was a very thin piece of stainless steel between the adhesive and molding on mine. I removed the stainless steel strip and all.If you do this,it makes the molding more flexible and it wont curl up on you,like most old molding does.
Side Trim
Quote from: Chooglin;173400
Yes, but I'm not planning on putting the molding back on.  It's the pieces between the wheels.
Side Trim
No joke on this one, I know it works as I've done it myself.  Avon skin so soft will take it off.  There's also lighter fluid that works sometimes, and rubbing alcohol sometimes works.  I've had better luck with using skin so soft though.
'86 cougar gone to the big yard.
'86&'88 Jeep Comanches.
Side Trim
Quote from: venom_cat_86;173584
I think I might have to borrmow some of my mom's and see what happens!
