Topic: new exhaust and slow boost (Read 3790 times) previous topic - next topic
i just installed a stinger exhaust on my 88 TC and now when i step on the gas the boost gauge shows that its boosting really slow.  the only thing that i have touched besides the exhaust is the intercooler to move it so i could see the downpipe.  i just checked and everything that i disconnected is tight.  i the car sounds like it builds boost but it goes nowhere, it feels like a dog now.  when i put the K&N on it really woke the car up... but now its slower than it was when it was totally stock.
 suggestions??? or boost leak somewhere?
boost leak
Quote from: SLEEPER T-BIRD 87;172167
boost leak
X2 - anytime you touch the intercooler, there is a change of not getting one of the couplers or clamp on there right. The other thing to look at, make sure you didnt knock the wastegate rod loose. Its down there where you were messing with the downpipe bolts.
Bob Myers
yea the exhaust would make it spool way faster, so theres a boost leak in there somewhere.
I am running the stinger exhaust installed by stinger himself.  check all of your boost/vacuum connections and fittings and lines to make sure you dont have a leak and also check to make sure that your intake tube isnt sucking closed under boost.  keep us posted
ok so i should check ALL  of the vacuum lines???
88turbo- what do you mean by the intake sucking closed under boost?
martin0660- should i check for play in the wastegate rod and what do i do if it is loose (dont think that i touched it though...)
Check all vacuum lines and intercooler couplers!
YAY i cant wait....
the intake tube going from your airbox to your turbo. there should be a spring inside to keep it from sucking closed under boost
ok just retightened everything down and replaced some hoses now it boosts like crazy!!!
now im new to turbos and do not fully understand them so i have a ?... when i stomp the gas to accelerate the car gets up to a certain boost level then goes back down to 0.  is this typical of turbos or is something releasing the pressure unnecessarily??
you have an IHI. Your boost drops out? Somethings not right it should hold full boost till you let out of the gas.
boost leak maybe???
 i dont have a BCS but i ordered a manual boost controller should that help at all?
You dont have a bcs? thats boost control soliniod right? You should have one, or the turbo is just going to boost as much as it can, i believe. How much boost is it making?
it keeps going up but i wont let it go past 18lbs  i have to shuft kinda quick lol
so shoulda manual boost controller solve that problem?
Yes. It will let you set the boost. Just make sure you put it in the right way
