Topic: power steering pump (Read 1245 times) previous topic - next topic
power steering pump
ok my power steering line blew out of my pump and im just wondering do i need to replace the entire line or just the connector? please help i dont know jack about steering or suspension im at least able to admit it
power steering pump
I'd just change the line since chances are you can find one for under 20 bucks
power steering pump
That would really depend on witch part is messed up. If the fitting on the pump blew out you need a pump. If the fitting that is on the line blew out then you need a line.  Unless either one blew out due to it being loose. Then you might be able to just reinstall it. Never know kinda need to get in there and dig around and find what you really need. Either way you might just want to get a new hose while you are in there working. The hoses are the weak link.
