Topic: Vibrating/squeaking door? (Read 1543 times) previous topic - next topic
My driver-side door has been vibrating/squeaking while driving for a long while now and it's starting to get on my nerves.  I imagine something on either end has come loose over time and use but I can't really open the door and check it while I'm speeding down the road.  It mostly does it when it's cold outside.  Can anyone give me a place to start?
Mine has done that twice.Once,the top rear corner was rubbing against the top of the car.You can tell by bare metal.Second,the door striker was missing the plastic sleeve and causing a squeak.
Hinge pins?
Quote from: thunderjet302;171764
Hinge pins?
Ditto
does the door close flush against the body? my car has the same problem(not very bad tho), i need to move the stricker, but im just too lazy.
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
Quote from: grutinator;171778
Moving the striker is stupid easy. You could do it and align the door in ~5 minutes.
i didnt say i was retarted, i said its not bad enough that im worried about fixing it. i only drive about 6 miles a day. so its pretty tolerable.
Where do i find the plastic sleeve to replace my broken ones.
Quote from: Carpimp1987;172085
Dead threads alive! Just thought I should let everyone know, that new door striker bolts(With sleeves) can be found on the turnstile displays at NAPA!
