Topic: difference between 86/87 eec harness (Read 8637 times) previous topic - next topic
Hello
  I have f***edup my ecc harness so bad its not funny(never use a 92 t-bird computer too many pins to change).  My car is an 86 elan t-bird built in 08/86.  I was wondering whats the difference between the 86 and 87 ecc harness and the computer?  I going to change the harness and computer this weekend. Do I need to drop my heater core for this job or will the harness slip by it?  What other harness can I use if I can't find one?  I need to get my bird on the road again so I can junk my caddy(pos)and get my bronco 2 on the road.
I need help fast.
Thanks in advance.
igiveup
86 ELAN t-bird all mustang parts (Sold)  I love this site.
85 bronco 2. Dura sparked (soon TBI) too many parts
1988 5.0 lx Stang (93 gt cobra mass air)
85 Honda 250sx trike
06 F150 tow rig. all kinds of goodies.(This is why I sold the Bird)
igiveup was the only name I could get. lol
There are alot of differences..  What year is your car?  If its in your signature I cant see it i have them turned off..
The interface where the engine harness connects to the fuel pump harness is different.  Where it connects to the dash harness is different.. and a few other connectors that are just different between the two..
Hello
  Its an 86 elan bird built in 08/86 with a 5.0.
igiveup
bump
I have an uncut 86 engine harness I can sell you.
Hello
I need to do this by this weekend.  My car is efi not cfi. I know 86-95 harness for the computer are quite similar.
igiveup
Yeah they are similar, but different... I'd consider the '91-'93 MN12 5.0 harness similar only, if you were referring to the wrap and dangling wires... Same for the '94-'95 Stangs... Those are major different...
Listen to Claude, he's documented the differences in these harness'... Being it's a very late '86(almost too late, I'd have thought '86 production would have ended in July), it could share some of the '87 traits... I've never modded a '86, but there are definite differences in '87 & '88 harnesses...
What would be diferent between an '87 and '88 5.0 computer harness?
The two connectors by the booster mainly.. And the lack of a VSS signal wires in the 87.
Quote from: CougarSE;171676
Yeah The '87 harness actually has three plugs vs the '88s two...
I have a converted to mass air '87 harness in my TC... Maybe not the best choice, but it's what I had on hand...
Will the '87 harness be a direct swap into an '88?
Hello
  I don't think an 88 would work because of the body change. Or was that 89??
  igiveup
the 89 up harnesses are a  compared to the fox harness.  They are integrated into the farking headlight harness even.. Stupid design.  Forget them.. Plus there wasn't a 5.0 mn12 harness in 89 ;)
Get an 86 harness and it will plug right in.  An 87 or 88 harness will require equal amounts of work to fit in your car.  Another difference, the interface for the dash harness is about 12" further forward on a 86 harness than an 87-88 harness.....
Hello
  Well I went and got an 87 harness and computer from the junk yard.
The 87 harness has different plugins by the battery.  So what I did is rewired the orginal to what the colors are on the 87.  Car runs but missfires so im going to do a tune up and see what happens.
igiveup
Will the '87 and '88 be a direct swap with each other?
