Topic: What kind of Cluster? (Read 2985 times) previous topic - next topic
I've never seen this one before. The gauges appear to be in the same location at the Turbo Coupe cluster, but everything looks different. What car is this out of? The guy claims it will work in our cars...
Bizarre Gauge Cluster
-DMC24guy
[/SIZE]
from a rustang maybe?
Dunno, but I like it.
Looks like the Turbo Coupe one but delete on the boost gauge. then showing a 4500 yellow warning with a 5500 redline that sounds like V8 (2.3's rev higher don't they? my old 2300 did)
did a sport ever come with something like this?
Nevermind...it's out of a Late 80's Mustang.
-DMC24guy
[/SIZE]
thought so
Maybe for a 3.8 ? I highly doubt than mine can go ahead 4000 rpm....and it has no rev limiter since is a carbureted engine !
Maybe for the canadian market.
1985 Mercury Cougar V6
1989 F-200 V8
1996 Explorer V6
2001 F-150
i thought it was for a thunderbird sport.
Quote from: DMC24guy;170620
Any idea what it takes to put in in an 88 Bird?
will it simply bolt in?
will it simply wire up?
This IS the style of dash cluster I would like to have if it would work.
Still don't understand why WE didn't get a voltmeter
1988 Thunderbird Sport
Quote from: Seek;170657
Good question, but when the '85 cluster was designed back in '84 few cars had volt meters... Would have been nice if they had rehashed the dash again for the '87s, but Ford wimped out and saved a few bucks... The '87 face lift did cost several Million $$$, so it's understandable why they decided leave well enough alone, on a design that was only going to be used two years...
Quote from: Jim_Miller;170630
Not even close.
I thought for a while that an 85 stang cluster would work as well...... no such luck
Quote from: Tbird232ci;170697
Not even close.
Well I was hopeing for an answer, but thats not the one I wanted!
guess that idea is :toilet:
It's an 87-88 non 5.0 cluster. It's only worth something if the lens is clean.
So you have a V8.......isn't that cute.
