Topic: Carb guys... look inside (Read 4262 times) previous topic - next topic
Quote from: 84 Fila;170395
What I'm looking for is the motorcraft equivlent of teh Holley 4010. I can't remember the name right this seconed but A few older ford guys I know told me it was the most " care free" carb once it's dialed in. Any imput on that
You mean the 4100 Autolite/Motorcraft, no such thing as a 4010(Ford) that I know of...
What you have is a 4300... Those make good doorstops...
As far as rich on a 5.0... No way... A small engine won't suck hard enough to pull the fuel through the boosters... If anything it would be lean...
Motorcraft/Autolight 4100
Quote from: 84 Fila;170444
Yup... I have one for a '65 289 Stang... A desireable  piece these days... One of these day's I'll ebay it...
Ok... Now I want this.... any + or - imput on this one? I talked to 2 random guy sat the dragstrip this weekend that had these on their older mustangs and the sang about them
it wont be over kill im running a 750 on my 351 and the cam sure as hell doesnt need it, but it sucks all the gas anyway!
Nuttin' too 'em...
The later ones('65-up) use a odd size jet, physically much larger than the Holley stuff... The earlier ones had Holley size jets but I understand the thread is different... Years ago when they were common, I just robbed the front jets from the 2bbl 2100 versions for the secondarys...
They come in at least two sizes but look identical(on the outside)...
The small one is 470CFM(small block) and the larger is 595CFM(big blocks)... The '69 351 used that POS 4300...
What pattern is it? And are you talking bolt pattern to the intake?
All 4100s used the Holley pattern... As do the earlier 4300s
Stick with the Holley. But buy a good rebuild kit and not a JiffyKit or some other POS. I'm too low on parts now to put together a kit for you, but I buy all my bulk Holley parts from Quickfuel.
Dave
I more then likely will go with the 650 DP for a while and see how it feels
Here are a few more of that old  4300D
I got bored and started building a 4180 Holley I had laying around today. I'm down to finding the fuel bowl screws and the meetering block and I have it all together. New rebuild kit and all new gaskets on it.  A question : can I use regular 4160 meetering block on this or does it have to be a 4180? The little added bonus of it being off a 84-5 mustang addeds to the fact that minus the cam.... the motor is 84-5 HO stang spec. If you have any 4180 parts let me know, I'm lookin
You will need a metering block from exactly that part number carb. Metering blocks are like the camshaft or computer of an engine, in that each is specifically calibrated for that carb, engine and application. Now, there is a lot of basic calibrations and even overlap of the same block being used on different carbs, but the chances are good a different block won't run right.
What is wrong with the old metering block?
Uh.... I don't have it. Don't ask.
I ended up Mocking together another 600 I had from parts. Another 600 vac secondary, 50 CC accelerator pump on duel inlet fuel bowls with 1 accelerator pump, no choke, purple accelerator pump cam. May or may not work, as it's only mocked together right now. All I can say for sure is everything physically fits. I'm getting 2 renew kits soon ( one for whats on the car and one for this carb) and we'll see where it goes
Quote from: 84 Fila;170840
I ended up Mocking together another 600 I had from parts. Another 600 vac secondary, 50 CC accelerator pumps, duel inlet fuel bowls with 1 accelerator pump, no choke, purple accelerator pump cam. May or may not work, as it's only mocked together right now. All I can say for sure is everything physically fits. I'm getting 2 renew kits soon ( one for whats on the car and one for this carb) and we'll see where it goes
50cc pumps are to large for your setup.
Swapped back to the 30 cc pump. Just waiting for a rebuild kit to come to the local parts store and I should have this on the car
