Topic: Open freakin' Sesame! (Read 2243 times) previous topic - next topic
Ok, there's a new Bird in my local yard, and it has a nice set of tail lights I want to grab.  Problem is, it has no battery and the keys are missing.  I don't want to pry the trunk open, cause it looks decent and  I might want it too.  Any suggestions?
351W in the works
Quote from: bhazard;300566
You got woman'd.
Purple w/ yellow wire from the trunk pop soloniod. Run 12V through it and it should pop the trunk
i figured pounding a screwdriver in the lock might allow you to be able to turn it
Mason's right.. if you don't wana use the locks. I did mine with a dill battery when i locked my keys in the trunk before
For just a one or so pop  deal on that little motor you could use a 9v. Either that or you could pull the back seat and get into the trunk and use a flat blade to turn the back side of the latch. That is if the car isn't nasty and bug coated. If you look under the deck lid above the plate area you might be able to get to the clip that holds the lock in. Pull that clip out and the lock slides straight out of the deck lid. I I think those clips are riveted to the deck lid. So pry it off. Look at your car for ideas.
First get a blow torch and cut a 27.33333" hole (you must be precise here to avoid complications later) up through the gas tank and into the trunk. Now place 8.63 oz (no more, no less) of TNT just behind the trunk latch and secure it with Orangatan glue. (even better than the stuff they get from gorillas) Insert the end of a 30' cordite fuse (You'll need those extra seconds trust me) and uncoil the remainder to a safe place from which to light it. (NOTE: Do not use electronic detonators as they might look suspicious to passers by) Build a small camp fire using a truck rim as a fire ring (think safety here) and drop the free end of the fuse into it.
In a matter of moments the trunk will magically open.
+1 mayhem
OMG!:laughing: :bowdown:  WAY TOO FREAKING FUNNY!
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
*Bows* Thank you. Thank you. And tomorrow, boys and girls, I'll tell tou how to remove a stuck lugnut using a forklift, a Dragonov rifle, used chewing gum and dog slobber.
just bring the battery in from your car.... violla!!
87 thunderbird turbocoupe
06 pontiac g6 gt
:birdsmily:
you need the key in the ignition to use the electric trunk button with a working battery in the car...
Quote from: daboss351;169583
booger up the ignition switch with a screwdriver.
06 pontiac g6 gt
:birdsmily:
Ok,, again. Jumper the purple with yelow stripe wire from the trunk botton to a batter or something, then hit the botton. It will pop the trunk. Not the ignition, you don't need it if your bypassing it.
Thanks for the tips.  I'll try to save the trunk lid, but if it come to it, :beatyoass: .
Might try Mayhem's on a Tempo......:evilgrin:
351W in the works
You got woman'd.
Doesn't the yard man have a big ring of keys that fit everything?
Fila's solution sounds pretty simple to me.
