Topic: lite rims? (Read 4106 times) previous topic - next topic
lite rims?
what are the cheapest, lightest rims that are out there?
lite rims?
cheapest and lightest is an oxymoron when speakin of rims
lite rims?
Quote from: gumby;168584
werd!
1979 Ford Fairmont
[/B]
lite rims?
not really. i saw light rims on ebay that weight 12lbs a piece for $399 for 4 rims... so hows that a oxymoron?
lite rims?
cause they were prob junk
use turbo coupe aluminum spares for light front wheels
lite rims?
i'm thinking convert to 5 lug and run the 89-92 ranger 10 hole rims... those are lightweight.
87 thunderbird turbocoupe
06 pontiac g6 gt
:birdsmily:
lite rims?
Tell us what diameter and width and bolt pattern you are looking for.
While you're at it, find me some lightweight 18"x12" with 5" backspace and 5x5" bolt pattern....
lite rims?
Quote from: daboss351;168642
That has already been discussed on here not too long ago... space saver spare wheels are really really weak.
lite rims?
Weld Draglite Wheels are the lightest and cheapest you can buy new for the 4 lug bolt circle.
TED
lite rims?
Quote from: Cad-T-Bird 500;168716
TED
being that weld is in bankruptcy, it might be hard to come across new wheels.  if you go that route, you'd probably have to buy used.
summit makes a weld knockoff that's really good.
06 pontiac g6 gt
:birdsmily:
lite rims?
Quote from: turboranger91;168721
I heard that too but Summit still sells them and most will ship today, so I don't think it's a problem.
http://store.summitracing.com/egnsearch.asp?Ntt=draglite+wheels&N=700+4294923105+4294755964+115&Nao=0&Ntk=KeywordSearch#rstop
TED
lite rims?
i did some investigating and it looks like summit bought all of weld remaining wheels.  there's a chance that weld might be able to come out of it, but that's contingent on another company loaning them the money.... which doesn't look good.
06 pontiac g6 gt
:birdsmily:
lite rims?
16x6 1/2, 4 lug, 4 1/4" Bolt Pattern will this fit my car good?
lite rims?
seems a bit narrow.
06 pontiac g6 gt
:birdsmily:
lite rims?
TED
I just bought a set of those for 350 bucks and they came with the same offset that my  old rims had. They weigh alot less than my Cragars that I had. And I don't have to worry about the center caps falling off.
:birdsmily:
