Topic: who runs 3.73's or bigger in a turbocoupe? (Read 5031 times) previous topic - next topic
Quote from: turboranger91;168558
that's what i'm getting at.  i've driven a lot of cars with 3.73's and they didn't feel so short.  that's what makes me wonder if the tranny isn't a v8 tranny.
A V8 tranny won't cause the problem, they have either 3.35 or 2.95 1st gears...  The four banger tranny has a 3.97 1st cog...
Factory the '87-'88 5 speeds have 3.55s and the auto's 3.73...
Guessing you're suffering from "AWOIS" (All Wound Out IHI Syndrome)... After 5K ain't much happning'...
could be the opposite problem. my early tranny has a 4.03 first gear. with 3.45's in both my rangers 1st and 2nd both felt too short.
i am gonna try a set of 3.27's this time around and see how they work.
no ihi... already t3 swapped.
87 thunderbird turbocoupe
06 pontiac g6 gt
:birdsmily:
Quote from: gumby;168563
the ranger still has the m5od with the factory 3.45's and it's  near perfect.
06 pontiac g6 gt
:birdsmily:
True, but I have doubts about being able to feel .06 difference in ratio...
Quote from: turboranger91;168565
So whats the 1st gear ratio of the M5OD???
so, if youve got 3.73's, was the car originally an auto? if so, i would bet that youve got an tranny with a 4.03 first based on the cable clutch setup.
Quote from: TurboCoupe50;168568
.06, multiplied by the .28 difference in rear gear that he is accustomed to, could be felt for sure
im sure its jus "different." jus gotta figure out exactly what you are workin with to know what to change
Quote from: gumby;168573
OK you're likely correct, I wasn't considering the difference in rear ratios...
Pick a gear any gear... LOL
M5OD    3.97    2.34    1.46    1.00    0.79 (Mustang 2.3L)
M5OD    3.35    1.93    1.29    1.00    0.68 (Mustang 5.0L)
M5OD-R1    3.72    2.20    1.50    1.00    0.79 (2.3L, 3.0L Engines)
M5OD-R1    3.40    2.05    1.31    1.00    0.79 (4.0L Engine)
M5OD-R1HD    3.40    2.05    1.31    1.00    0.79
M5OD-R2    3.91    2.24    1.49    1.00    0.80
M5OD-R4 / M1HD    3.38    2.06    1.30    1.00    0.79
M5HD    4.14    2.37    1.42    1.00    0.77 (Close Ratio - Gasoline)
M5HD-W    5.72    2.94    1.61    1.00    0.76 (Wide Ratio - Diesel)
M5R2    3.75    2.32    1.43    1.00    0.75
M5R2-C    3.42    2.16    1.34    1.00
Guessing it's probably the 3.72????
yup, 3.72 should be correct for his ranger.
i didnt recall the M5OD ratios, but that puts an even larger gap between what is in the ranger and what is in the TC
3.72 and 3.45 vs. 3.97(or 4.03) and 3.73
sounds like its time to figure out what tranny is in there for sure, and pick a new rear gear if you dont like the 3.73's
i just got a pm back from the kid i got the car from and he says the the tranny is in fact a 4 cyl world class t5 from an 85 turbocoupe.  it's a cable settup.
06 pontiac g6 gt
:birdsmily:
M5OD's came in mustangs?
the one i was using in my rangers is an 85 unit also. that should be a 4.03 box.
Quote from: bhazard;168678
i don't think so.  as far as i know it's always come with a t5 for the manual cars.
06 pontiac g6 gt
:birdsmily:
I believe the site I plucked the info from lumps all the RWD trannys into one category... Why they are calling the T5 a M5 I dunno...
Looks like I left off the T5...
linky http://www.vibratesoftware.com/html_help/html/Ford/Ford_Transmissions_Main.htm
At any rate the WC T5 4cyl tranny has a 3.97 first gear... the '84 non-WC tranny was 4.03...
