Topic: Tbi To Fuel Injection (Read 980 times) previous topic - next topic
So I Have A Freind With A 5.0 Tbi And He Wants To Know If He Can Convert Over To Fuel Injection .if He Would Only Need The Plentum Wiring Harnes And Computer Mabie Upgrade The Distrib ...what Would Be Involved And How Much Difrence Would It Make
Fuel lines,fuel rail.If you have a complete donor car,easy enough.
He's already fuel injected,, :D CFI correct?:evilgrin:
he could try out the following
transfer everything from most any 86 and up 5.0 standard output system into his car.  that simple.
this should include
upper/lower intake
fuel rail system
TV/throttle cable system
harness
eec (investigate serial numbers last 3 digits for perfromance reasons)
fuel line system to transition into the newly obtained fuel rail system
Be sure the engine/EEC harness will connect to the cars body harness... Ford has a knack of not making those a direct swap...
