Topic: Turbo is here :D (Read 2844 times) previous topic - next topic
Turbo is here :D
Hey guys,  The friend of mine that does International truck engines for trade shows called me up today to see if I still wanted the pair of turbos he had promissed to give me a couple of years ago. You bet I do... :D I went over to his shop and he gave one of them to me. The other one had been packed into a crate to be moved to his new shop, so when he unloads that crate, he'll give me the second one. They are for a 360cid I6 truck engine. If I read the numbers right, the A/R is 1.32. The intake turbine housing says AirResearch T04. He is also giving me alot of the intercooler tubing to work with.  He would've given me an air-to-air cooler too, but they are waaaayyyy to big to fit into my Bird. Oh well, at least I can start making the brakets, s and such.
John
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Turbo is here :D
Can I have the 2nd one?
Turbo is here :D
:flame:  JK,  Sure, as soon as I'm doing using it.  :evilgrin:
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
Turbo is here :D
what size is the inducer/exducer, intake/exhaust housing? is it a T6 ?
1979 Ford Fairmont
[/B]
Turbo is here :D
:ttiwwp:
Turbo is here :D
Not quite sure what you mean 32Vfoxbird. If I can get some pics taken, I'll post them. It's not an overly large unit though. I just looked at it agin in better light. I misread the A/R #. It's 1.32 not 1.62.  any ideas as to where i can find out those numbers you wanted??
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
Turbo is here :D
there should be an a/r # on the intake housing, and exhaust housing. you can measure the blades with a ruler.
1979 Ford Fairmont
[/B]
Turbo is here :D
The a/r # was only on the exhaust housing. I'll take a ruler and get some measurements and post em.
Yes gumby, I'll post some pics :(  LOL
John
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
Turbo is here :D
I thought the cummins 5.9 came with a holset?
Turbo is here :D
Wrong brand of engine. spoogings vs. International Harvester. The engine this came off of isn't the engine used in the Dodge p/u's. It's the ones used in bigger trucks but not semi sized.
32vforbird; the exhaust turbine measures 2 11/16"; Intake turbine measures 2 9/16" and the intake outlet tube measures 1 7/8" That is using a ruler. Not the best measuring device but that gets me close, I think.
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
Turbo is here :D
Sounds like a TO4B to me...
So you have a V8.......isn't that cute.
Turbo is here :D
Post up some pics.
If it's a T04, then it's obviously gonna have a T4 ...just dunno which compressor side it has, T04E or T04B. Easier to tell with a pic.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Some Turbo Pics
Ok guys, here are some pics of the turbo I told you about. Hope you can see them alright. If not, check out my cardomain page. That's where the rest of them are. If there is an easier way to post them....please let me know.
John
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
Turbo is here :D
Hey, I figured out how to post the pics. Shock :hick:
Sorry the pics are rather big. I didn't realize they were so huge :(
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
Turbo is here :D
Those aren't big. In my opinion, all pictures posted should be that size or larger. I absolutely hate squinting at the little 320x240 things people post.
If you mean file size, yes, they could be around 20KB each instead of 70-100KB.
1988 Thunderbird Sport
