Topic: Head options (Read 3558 times) previous topic - next topic
Head options
Here's what I got: SO block (dished but not reliefed pistons), HO cam. E6 heads, Comp cam 1.7 fully adjustable roller rockers. Changing block is not an option right now with the work area I have.
Question??? What aftermarket heads could I use with SO pistons, HO cam and 1.7 pedestal rockers?
Does anyone have comments on the Edelbrock performer 5.0 (1.90 intake valve) as a viable option?
What about the AFR 165, could these be used for this application?
I was thinking of self porting a set of E6's. Is this worth while? Pros - cons?
I already have a set of E7's on the work bench. How about porting these for my set up? Could they handle 1.7's, HO cam and SO pistons?
Keep in mind funds are tight, separated (car/motorcycle widow...LOL) and divorce imminent.... Whatever I do has got to be an affordable choice for what is a street driven garage toy usually taken for cruise nights and show n' shines. Thanks
87 Sport with HO cam, 19# injectors,TB+Upper Intake,87 Mustang EEC, Cloyes double roller timing chain, Kirban adj. fuel regulator and Autometer fuel pres. guage, HO shorty headers + LSC H-pipe and Dynomax Super Turbo lers, Ford Racing 9mm wires, K&N filter / no air resonator, 8.8 XR7 Diff., V rated tires, Project ongoing.
Head options
Anyone?
Head options
port the e7's
Head options
Quote from: SLEEPER T-BIRD 87;167633
port the e7's
^ what he says ^
Head options
Unless you just can't afford a aftermarket set, I consider messing with any stock head just "' in the wind"... Sure you can port the Hell out of them(they'll probably crack) and install larger valves, but you still have a heavy iron head... If you're on a tight budget, aftermarket iron heads or GT 40s are a far better choice, but you'll really need valve relifs in the pistons...
That said...
Trick Flows are the only aftermarket head that will likely have enough valve clearance... I've been running a set on a '86 HO shortblock(no dish, no reliefs)since '99... Plus I've had them cut .010 to true up the surfaces, after I blew a HG spraying... I also have the Stage1 TF cam with .499/.510 lift @.050 and 221*/224* duration(1.6 rockers)... This is not a combo to run on SD, Mass Air will be mandatory... Guessing a stock cam should work with 1.7s on the SD...
Head options
From your responses, I gather that porting my E7's would work with my HO cam, SO pistons and 1.7 roller rockers. Right?
TFS twisted wedge heads do sound tempting, but would the Edelbrock Performer 5.0 1.9 intake heads work with 1.7 rockers etc? It would take me longer to get the cash for theses though.
I have the mass air stuff to put on when needed. So SD problems aren't a concern.
I'm convinced GT40's are out of question unless someone has good suggestions on how to grind valve reliefs into pistons while still in block and still in car.Thanks all, looking forward to your replies.
Head options
You can get an ISKY tool to do the valve reliefs while the engine is in the car.You have to be wicked careful,and it takes quite a while.You have to pull the head and re-install it to do every valve.That's 16 times.
Head options
Quote from: SRBird;167899
TW heads have the valves rotated slightly away from the piston(more toward the ports)... They even advertise, unless you use a huge cam valve reliefs are not needed(and exactly why I bought mine)... I dare say NO other aftermarket head is going to work with flattops...
Tom
Head options
You could port your e7's and they MIGHT work with 1.7's but I'm unsure of the exact v/p clearance you would have. In addition, even with a port job, out of the box tfs' will out flow the ported e7's any day. Plus, with the tfs twisted wedge, adequate valve piston clearance is easier to come by with higher than stock valve lifts.
 I'm all for low budget builds and making stock parts go fast, but there is only so much even a professional porter could do with e7's.
 Hope this helps,
  Mike
Head options
I hear ya's. Porting the E7's could be touch n' go with the 1.7 rockers, That's why I even considered doing the E6's.
I've long thought that forking out the bucks for TF twisted wedges was the way to go; but from all the reading I've done, I started to get concerned that the 2.02 size valves may be a little big and might cut the lower rpm HP and torque that's needed with an AOD stock tranny. Nice to have high HP but if it only comes on after the tranny upshifts then "OH WELL!". What are your thoughts on this? Valid concerns or would I get "seat of the pants" type burn outs anyhow?
ISKY tool? Yikes! on the head install & removal for each valve, I'm sure I wouldn't be the first one cutting corners by the 7th valve. Is it doable by your typical half-ass shade tree mech?
PS: I also have an Explorer intake to put on when I change heads.
Head options
Worry more about port volume than your valve size. The smaller intake runner promotes velocity, which promotes torque. The valve size makes a difference in torque, but the role that velocity plays is greater than the valve size.
I would also say, go with the twisted wedge heads. Theyve proven themselves many times, and will work with your pistons.
Head options
I would LOVE Twisted Wedge heads,but for now,NOT in the budget.After buying everything I've bought in the last 2 months,my budget is wicked small.I'll probably end just selling the cam and stashing the money away for other projects.
Head options
I assume the twisted wedge are aluminum?
Head options
Yup, the pair weigh approx same as one iron head...
I dare say a little less even.  The 2 fully assembled heads felt slightly lighter than one of the iron E7's I pulled off 2 winters ago....
