Topic: efi (Read 2660 times) previous topic - next topic
efi
What can I do to get the most out of my EFI on '88 TBird 5.0? I want it to run but also like to drive it around town.
Re: efi
Simple cheap mods or serious engine work?  The latter will almost always necessitate the switch over to a mass air system.  Otherwise your limited to bolt-ons.
Re: efi
Got another 5.0 motor thinking of carburating it. I intend on building the motor to make it a street racer and was getting ideas on which way will be the best, EFI or carb. I know EFIs can be a handful at times and carbs are a bit more tweak friendly.
Re: efi
tweak friendly for those who don't have access to a Tweecer or know how to mess with the computer. but that usually is only necessary when you have forced induction or something major. the mass air system will take a H/C/I swap no problem, but it's usually a good idea to get it tuned when you do such mods
Re: efi
EFI is only tough if you're converting a car TO EFI, otherwise it's relatively simple.
PS - Street racing is dumb, aside from shwoing a few ricers up now and then, it's a bad habit to get into.  You can lose your license pretty quck too.
Re: efi
Our street racing is done at Bristol Mortor Speedway. We have drags, burnout contests, slowest time contest. Anybody can enter. I've seen everything from GEOs to 3/4 ton pickups. Its quite fun.
Re: efi
Ahh, I stand corrected.  By street racing I thought you meant it took place on public streets. Just street rod sort of thing... street/strip cars I take it.
