Topic: what exhaust do you run? (Read 6912 times) previous topic - next topic
Quote from: 1WLD BRD;167113
LMAO you also have your lers on wrong! they should look like this:
I was gonna point that out - they look like they're dumping directly onto the diff housing:hick:
*EDIT* Actually, after looking at it again it looks like they're the wrong lers anyway - they look like "center inlet" lers. They're actually touching each other...
i think he got the wrong inlet/outlet configuration. they look like what's on the 03/04 cobras.
1979 Ford Fairmont
[/B]
BBK 1 5/8" shorty headers, BBK catalytic H-pipe, Flowmaster 2 chamber 40 series, 2 1/2" throughout to tips, sounds great and I love it. :D
[SIGPIC][/SIGPIC]http://www.fquick.com/slicksport88
88 Sport - 5.0HO, Mass Air, A9L, 73mm C&L meter, BBK CAI, 255 lph pump, 1.7 roller rockers,Professional Products damper, Chuck W motor mounts, BBK shorties & H-pipe, Flowmaster 40 series, 8.8 rear w/3.27's, 93 Cobra M/C, BAER 13in. drilled/slotted rotors front and back, cobra calipers, Russell braided brake lines front & back, C/C plates, 03cobra rims, 255/40/17 Nitto 555's all around
h.o. headers, mac 2 1/2" off-road x-pipes, and mac 2 1/2" mustang lx catback.
At the moment. Stock manifolds, cats, Y pipe, cut at stock ler with a Magnaflow hanging there.
I have shorties, but am in dire need of a catless or high flow catted H pipe. I have Stainless Stang GT Tails, and Magnaflow tips, just missing the center section.
That ler arrangement looks atrocious Mikey...cut'em off and start again!  As far as turndowns, go with just enough so it looks like it's directing exhaust gas just under the rear axle...otherwise the sound will just reverberate off the ground and give you a headache...either way, i still say tailpipes are for pusswads! lol, j/k...
I was driving next to a concrete highway divider today and my exhaust sounded like absolute ...sounds WAY too mellow for full length headers, no cats and 40-series flowmasters...off with the tail pipes, I say!
I had a 40 series on my birdie for quite a few years before breaking the stock motormounts. Sounded pretty good but the rest of the exhaust was stock :(
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
3.5 inch mandrel bent pipe to a dynomax bullet and dumps right next to the tranny.
87 T-Bird turbo'd and supercharged and if things call for it juiced. :evilgrin:
88 Turbocoupe t3, 4.10's, Daily driver
As it stands right now, Slopoke's exhaust is pitiful :mad: . Fake factory duals, some turbo knock off lers and the cats were supposedly gutted.
 That will change soon, :evilgrin:  upr x pipe, borla xs lers, pypes flowtubes, and jba coated headers. Just need tailpipes, hangers, clamps, and exhaust wrap.
  To desktop dyno exhaust seems unimportant for forced induction, because it 'grays out' that section and won't let you change it. Maybe they think if all that fuel and air is going in it has to come out  or is it for some other reason? :confused: It shows to definately make a difference in normally aspirated engines.
Reply #39
uh factory ho headers, factory h pipe, thats it right now sounds OK, a little to quite for me, no joke, 4 cats kills is big time
coming soon, mac h pipe with gutted cats, flowmasters and 2 1/2 tails.
Reply #40
Quote from: SLEEPER T-BIRD 87;166643
open 3" downpipe on my bird
http://youtube.com/watch?v=y5XWHriprws
Reply #41
dang, all of you guys have good exhaust systems.
all i have is a catback..... my father told a exhaust guy for a whole new dual exhaust but the idoit only did a new cat and bigger pipes after that.. everything is still stock from my stainless steel headers to the new highflow cat. (yes, i still even have those 2 little cats after the headers....
the exhaust guy said a true dual exhuast couldnt be done without alot of prep work because there are wires where the pipe had to go underneith the drivers side.
Reply #42
oo i have flowmaster thunder series. with 3 inch polished stainless steel silverline exhaust tips. and i have 2.25 cat back.
Reply #43
3" downpipe, 3" intermediate pipe, dynomax ultra flow, and no tailpipe.
Reply #44
glad to see alot of folks know about the EVILS of py ass flowmasters ,the worst flowing lers on the planet .(after stock)
Mine has a 3 inch downpipe to a 3 inch convertor to a 3 inch dynomax turbo ler then a 3inch tailpipe
