Topic: Cleaned up some under hood (Read 4424 times) previous topic - next topic
Here are a few pics from me cleaning under hood. It may be a repost to a few people pics wise, but I have a question. When I was cleaning the strut towers, firewall, inner fenders..... the paint kept coming off and I was left with a grey primer I assume. I didn't use any harsh cleaners( a rag, dawn with bleach and a scrubbie pad for the really tough sticky black stuff) and paint still came off. My question is do I scrub ALL the paint off and have the underhood grey primer or re-paint it white?
From this:
To this:
This:
To This:
And the best change pic... This:
To this:
looks like you should tend to the oil leaks first.
87 thunderbird turbocoupe
06 pontiac g6 gt
:birdsmily:
I'm soaking the block in de-greeser today hopefuly if it doesn't rain again. It doeasn't apear to pour out any oil, and that may be from when I pulled the water pump and just didn't clean all the fluid off or something. I'll know soon.
After you get the engine clean,paint the under hood area.Did you install a new o-ring on the distributor?You may need one.Also,is it leaking oil from the front and rear of the intake?
Around the intake was from when I pulled the radiator hose. As for the oil leak it was the old seal from the timing chain to oil pan. All it cleaned up now. Dizzy o ring was replaced. What color should the underhood area be painted? Oppions?
White is just not a good color for under the hood, That's for sure. :hick:
I was gonna either keep my factory midnight charcoaly color, Or go black on mine.
BTW~
Are you running the car without the coolant overflow tank thinger? And does it run fine without it?
Really bright pink! Should be body color?
Quote from: Romeo2k;166510
BTW~
At the moment yes, I don't have the stock one in. I'm going to mount one in front of the radiator like the later V8 cars.
As for the color I may try to "wash off" all the white paint and leave it grey primer. Then again kinda like the body color white as well. It really sets off the underhood. Atleast it's something pretty to look at
Hmm, Sounds good.
The reason i say it isn't the best choice is because the dirt likes to cling to the white and make it grungy looking. :hick:
Yah,
I was thinking primer too for mine, So i could do small areas as i went along.
Then it will already be mostly prepped.
And later i could pull the engine and junk out, And paint the whole thing up nice.
Thats the whole idea. This motor isn't staying in forever. Even if I just rebuild it it has to come out and I can weld all the holes and paint it. Just looking for a solution now as it looks worse with grey and white area's then it did covered in dirt
Look near the header, you see ALOT of grey ptimer color
I gave up my loosing battle underhood and cleaned up the rest of the car a bit as well. Still looks like  but I think it's getting better
yeah it looks better clean.  Pull the motor and scuff up the inner fenders and paint the engine bay body colour. Looks way better.
Thanks RJ!
Should I do Rust-o-lium paint or just walmsrt $.99 white?
rustoleum and krylon is good stuffs. :hick:
id do it matte black.
