Topic: i need 5.0 motor mounts! (Read 1768 times) previous topic - next topic
allo, i swapped ina 5 litre for my 3.8. its been hell since the day i did it! i need motor mounts. if anyone has them pm me or emial me at loko_munki@hotmail.com thanks!
Re: i need 5.0 motor mounts!
well if you are talking about the brackets that go between the block and the mount for an 87-88 we are in the same boat...
Methos
I can get you these mounts, if you still need them.  how does $25 a set and $10 for shipping sound?
why dosen't anyone carry the brackets? the mounts are the same as a v6 aren't they?
THERE'S NO REPLACEMENT FOR DISPLACEMENT!!
1994 ford cough aerostar cough :shakehead
1985 mercury cougar 5.8 fmx 3 speed 4.10s in progress :welder:
Pep Boys has the mounts for $35 each with warranty.  Also, both of my mount brackets were broken on one end and I had a friend weld them back together.  Worked like a charm.  So if you still have broken brackets, you can fix them.
Ford discontinued the brackets.  Just like a lot of other parts for these cars.  :mad:
I saw some on e-bay under "1986 to 1988 Thunderbird accessories".
to bad my cat is an 85.... are they the same?? also does anyone know if summit has any brackets?  I saw that they now carry solid motor mounts for muskrats but i don't know if they are two-piece like the cougar/t-bird units so you might still need the brackets.
