Topic: Air Silencer (Read 1689 times) previous topic - next topic
Air Silencer
I've searched and searched and people talked about removing it, but no one actually showed anyone where it is, I'd like to remove it but I don't know what it looks like.
Air Silencer
its behind the airbox were it bolts to the inner fender panel.
Air Silencer
Thanks! Have any idea what it looks like?
Air Silencer
Quote from: 302 PWR;165613
cant miss it it goes through the hole in the inner fenderwell faces forward towards the headlight.
Air Silencer
Ok, I'm going to take it out right now. I guess I can post some pics.
Air Silencer
Do it up.  When I took mine out I could tell even on my 3.8.
Air Silencer
Finished  that took a long time, I also cracked the cracked filter holder even more. Getting the silencer out was the hardest part!
Air Silencer
What does the air silencer do anyway silence the intake of air coming from outside im assumin?
1988 Mercury Cougar LS 5.0L AOD 2.73 :cougarsmily:
1993 F150 XLT 5.8L E4OD 3.55
Air Silencer
Yes.
Air Silencer
Here it is:
I'll go and buy a K&N filter tomorrow, after I find a mint airbox at the J.Y. or order a new one from Ford. Oh and I didn't notice any thing after the removal.
Next question:
I read I can bump up my timing but only if I run a higher octane, I run 92 and 94 everytime I fill up so I assume this would suffice?
Air Silencer
Yep that is your silencer.  I removed mine in the RRI parking lot at CJ, and installed my CAI.
You can bump the timming without running higher octane fuel, you just have less of a window of degrees to do it.  I noticed a huge difference after both mods.
Air Silencer
Quote from: 1WLD BRD;165686
Did you do both at once or just one at a time? I did each one at a time and I really didn't notice much of a difference after taking the silencer out. I noticed much more after bumping the timing:D
Oh and I really noticed a difference on the HO when going from 10*-14*. It was much more pr0nounced than on the stock 5.0.
