Topic: f/s 87 turbocoupe 6,800.00 (Read 4872 times) previous topic - next topic
Thunderbird Turbo Coupe
Has decent base/clear paint normal door dings has a 6-7" lift off VFN hood that is ready to paint ,6 point cage,EZ wire harness from front to rear,8.8 rear with full spool,3.73 gear,strange axles,5/8th studs ,girdle,C clip eliminators,Southside lowers and stock uppers,8 gallon fuel cell,1/2 lines,-8 braided to carb and fuel pump,aeromotive A100 pump,Stainless screen filters,Aluminum battery box,all rubber plugs were replaced with metal,floorpans sanded and painted flat back,Factory moon roof car,black carpet,Manual window conversion,5 point driver harness,Mustang Lx seats,Nice Black dash pad (dyed) and console,autometer gauges (oil/water/tach)no speedo or related.Grant Gt challenger wheel ,Hurst pistol grip quarter stick shifter,Stock front suspension W/5 lug conversion,Th350 trans W/shift kit and 2,800 stall,custom driveshaft,poly mount,310 cu in SBC, flattop pistons aprox 10.1 ,moly rings gapped for nitrous,main studs,windage tray,crank ser,pan baffle,crane 246/500 lift cam,comp cams double roller chain,Single plain intake,gasket ported heads,1-5/8 shorty headers,roller rockers,HEI dizzy w/supercoil and locked advance,Zex perimeter nitrous plate,Edelbrock RPM big selonoids,-4 and -6 feed lines,Full 10 lb bottle,Aluminum radiator,electric waterpump,aluminum catch can.dry cell battery,taylor cables.15x3.5 prostars with brand new 165's and 15x8's with near new 28-10.5w's also comes with a pair of drag radials mounted on stock mustang wheels.
Motor has been 7.90 on the motor and 7.17 on a 150 hut with shiznitty 60's
Should run 7.80-7.70 on motor and 6.99 on a 150 with the additional work.
motor/trans has less then 1k since freshened up.
No joy rides,no B.S,You get what you see.
May consider trades towards pre 74 car/truck etc or 2000+ economy car
6,800.00
Dude, you've got automotive ADD. I've never seen anyone build and lose interest in cars so fast...
Quote from: Thunder Chicken;165600
yeah :D
Also forgot to ad, Car has a wideband o2, and absolutley no rust
Well... I have to ask... what did you buy now
Quote from: 84 Fila;165626
nothing
Interesting how you carbed it?!?!?!  Its looks like a rather interesting and simpler way of approaching it than the FI
few pics without the hood
that's a hell of a nice car.  good luck with the sale.
87 thunderbird turbocoupe
06 pontiac g6 gt
:birdsmily:
what does it run with the stang motor?
1979 Ford Fairmont
[/B]
It HAD the stang motor. I belive he swapped it back to the 2.3T for his current 1/4 times
Quote from: 32VFoxBird;165702
I dont have no timeslips for this setup, I may take it tonight and make a few T&T passes
make offer.
hsw
i'd love to make an offer, but i think my wife would kill me.
06 pontiac g6 gt
:birdsmily:
ill give you a dollar.
