Topic: 5.0 injector harness (Read 1760 times) previous topic - next topic
I was just putting my injector harness on my motor and there is a plug that will drive me nuts soon if I can't remember where it goes. It is on the left side of the harness, is the last piece on that side, is identical to the water temp sensor plug and extends about 10" past the harness. I would eventually find it, but I figured I would ask.
Jim
i believe it has something to do with the smog equipment.
1979 Ford Fairmont
[/B]
Oil sender?  What left are you talking about?  Driver or passenger?
oil sender plug looks like the small "push-on" wire that's on the starter solenoid.
1979 Ford Fairmont
[/B]
I know this.  I forget what the coolant plug looks like :(
Now there is the connector for that stupid canister purge valve.. is that it?
You two are right..oil pressure gauge sender. Mine is removed due to an aftermarket gauge and the feed for the supercharger. Thanks!
So got the motor in,gettin there.
Almost...doing a little preassembly while it's on the floor. I figure end of next week it will be sitting in the engine bay!
Is it your brothers yet? Is it at your place yet?I feel the urge for a short ride.
once again the thundr306/thunder306 confusion. This is the Jim that you got the rear, sunroof, etc from.
I know,sorry for the confusion,Wow I need to take back a few post.Short ride still good.
