Topic: inner tie rod replacement (Read 1678 times) previous topic - next topic
I have some play (about 3/8" - 1/2") in my passenger side inner tie rod. Is there any tricks I need to know to replace this? I have never done this, so any help would be great.
Our web page
02 Explorer XLT 4.0L
04 F150 FX4 Supercrew 5.4L
02 Saturn SL1 1.9L
09 Vstar 950 Tourer
Best I tell you is to take off the boot and then loosen the thing up. There is a pin that is a hold in thing but just crank it off of there and put the new one on. Make sure to mark where the outter is marked on the inner so you can get the alignment some were near wear it was. Pretty simple. Need to get an alignment after you are done.  They do make a special tool to take off the inner but I got mine out with a Big wrench.
Go buy a 15:1 ratio rack out of a turbo coupe like I did(preformance package).I had the same problem with my drivers side very happy with it.It was only like $120 or so.
P.S. the stock one is 20:1 ratio
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
