Topic: 351 Engine Swap (Read 8520 times) previous topic - next topic
351 Engine Swap
As some of you already saw this coming from my few posts questioning issues of squeezing in a 351 into a fox. I figured id make this the main posts. Personally I’m getting a lot of positive impute on throwing in the bigger 351. The only hard obstacle I see right now is the hood clearance as for the oil pan they sell a kit and the front assembly too.
Where I’m getting mixed opinions from is staying w/the EFI or going CARB. Knowing most of you on this forum I think most will say EFI but there is a difference in cost especially if I decide to up the heads and cam or even stroker it on a latter day. Gas mileage means nothing to me since the car is a weekend warrior. And a carburetor would look so nice under the hood. And it would make those hood scopes operational on the turbo hood but now im getting a hint that a carb 351 won’t clear either.
351 Engine Swap
I'm in exactly the same boat and leaning exactly the same way, right down to the Chucky mounts :hick:. I've pretty much decided on going carbed with my 351 swap. I've only put 3k miles on the car in two years and it will never see winter driving again, so cold weather drivability and fuel economy aren't issues. Cost is, and the carb setup will be much, much cheaper than EFI. With a carb setup we're looking at a distributor, intake, fuel pump, cam and carb. With EFI we're still looking at a distributor, cam and fuel pump (stock pump and dizzy wouldn't be sufficient and stock truck cam would just be foolish), plus a very expensive intake, injectors, throttle body, MAF conversion, MAF computer, etc... The money I'd save over going EFI would pay for a set of TFS heads.
I also wonder about it clearing the stock hood, but if it won't clear the TC hood it should clear the stock flat hood as long as I use a reasonable intake and low profile air cleaner...
I've even considered making a custom air cleaner and connecting it to the hood scoops in a TC hood to make a ram air setup, but that would be way out in the future. Another idea I'd had was to cut a hole in a flat hood and use a 70's Trans Am shaker scoop/air cleaner assembly
351 Engine Swap
On the day I went to look at Hillbilly Deluxe she had a carbed 351W in her. I can't give you a lot of details as I bought her without motor and tranny. I did manage to snap this pic of it and there was plenty of hood clearance to close the hood.
351 Engine Swap
It can't be done.....You should sell me the motor:hick:
351 Engine Swap
Thunder Chicken looks like me and you are going to be friends for a while now. You probably now this and saw this already but I found a good link for going from EFI to CARB.  http://www.jason.fletcher.net/tech/efi-carb/efi-carb.htm
Paul no you cant have my motor actually I’m picking it up either Mon, Tues, or Wed from Lakewood JY It’s coming out of either a 94’bronco or a 97’p-up both not running but I’m rebuilding anyway
351 Engine Swap
Thunder Chicken its funny you said "flat hood and use a 70's Trans Am shaker scoop/air cleaner assembly" cause I was thinking of using the flat hood and w/a high rise intake Carb and air cleaner sticking out like a circle track car or like sleeper car use to be like w/out the T/C hood. Shakers are assume.
351 Engine Swap
Awesome?
351 Engine Swap
I'm going to use a carb.  With my Yates heads, running EFI would be very expensive. I have a very tall intake, but hope I can sit the motor low enough to clear the flat hood with a reasonable air cleaner.
351 Engine Swap
i have a 351 in my 87 sport, with a victor jr intake manifold and a demon 825 carb, to use an air filter i need a hoodscoop or to cut the stock hood, without an airfilter or with the carb "hat" used for storage i can close the hood with no problems
1987 351 swap, T5, ac/smog/power steering delete, custom H pipe Borla ProXS lers..
351 Engine Swap
I bought a 14" aircleaner(replica) for 67-69 camaro on ebay. It has a smooth dropped base and should allow a reasonable filter element and still be super-low-profile. You might try one.
I'm going to use an "airbox" and pull cold air from the cowl.
351 Engine Swap
Just read some where that the 351 is 3 inches taller then the 302.
351 Engine Swap
Starting to lose my patience w/the JY there again today and they still did not pull the motor I feel like pulling it my self. Though in there defense I do no them and they said they thought they had one aside for me and then they realized they sold it.
351 Engine Swap
'Just read some where that the 351 is 3 inches taller then the 302."
Deck heighth on a 302 is 8.2", and the 351 9.2", so the vertical difference would be less than 1". But intake manifold choice will dictate actual hood clearance.
351 Engine Swap
Haven’t updated lately but been busy sorry for that but for now my 351 project is on hold. Kinda annoyed I swear there’s 351 everywhere till I need one anyway time was going by to quick and the summer is almost over and I want to enjoy the car so I put the 302 back in the machine shop. Just got it back w/all the parts so maybe Monday ill do the reassembly.
I’m still going to do a few small tricks to it. And in the future I do plan on putting in a 351 Windsor motor possibly stroked. The more I think I’m probably better off doing it this way cause money should go other places in the car first. Like I might be buying a tranny, suspension, brake upgrades ect.
