Topic: well i got a few parts (Read 1726 times) previous topic - next topic
Went out in the country to pull a 350 out of my brothers camaro to throw into my dads new truck, and looked around and i found a drivers side tail light for vinnie, a carb and coil for fila, and a set of snowflakes, and a set of ten holes.
my dad said i might as well try to sell the ten holes we got, they are 15's and hes got another set of 16 inch snowflakes he said i could sell, and a set of 15 inch turbines, plus what ever else i pull off the black turbo coupe next week.
more to come
Nice ;)
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Unequal length headers
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
vinnie there you go one none faded or cracked tail light.
Carb and coil bracket pic lil bro?
as you wish
carb needs to be pulled apart so i can check and make sure its all in good shape, as of right now the secondarys are jammed open, so if not i know where theres a 650 double pumper sitting
Is that a big ass spreadbore like the one I got from a 460?
I'm kinda intrested in the 650, as I would rebuild it and have alittle fun with it too.
not even close. it will bolt on a 302 my dad said, he said it would be perfect for it the motorcraft one is a 550 he thinks, ill have to find the 650 next week for you
Is it a spread bore ( the butterflus are 2 different sizes) or a square bore ( butterflys are the same size) though. Thats what I need to know
spread i think, i think we have a intake it will bolt to also
Allumnium or Iron? If it's a spreadbore i'll have to say no, as my current intake is a square. I duno, let me figure this out as you find parts lil bro
the 650 double pumper is square
Intrested in the double pumper if it's in ok condition. What about the Motorcraft?
figured you want the 650, my dad said i can sell you them both he dont care, the intake he has is just a stock iron intake and i think its spread bore to match the motorcraft. Didnt get into looking at it today was welding and porting manifolds and putting a clutch on the 350 so we can stick it in the truck.
What would you want for a set of snowflakes or turbines?
