Topic: Transmission solution for my TC (Read 3518 times) previous topic - next topic
All this time I've planned to put a 5 speed behind the 5.0 when I get my butt in gear and drop the engine in.  But I've changed my thoughts and want an AODE.  So my simple route will be a 94/95 GT Auto computer.  I'll have Maf and means to control the AODE.  Not much of a thread.. but I'm bored and thought I would see what people thought..
Are the AOD-E's the ones you can electronically shift?  Or are those the later 4R70W or whatever?  Paddleshift ftw.
nice thread, now DO IT!!
:beatyoass:
4r70w
What year did they switch to a 4r70w?
94 for Thunderbirds?
Unsure for SN95s
Oh,, I duno.. well either way it will work..
Do they have the same pinouts?
Does this mean you won't be needing that T-5 and the pedal assy.? :D
According to Mitchell OnDemand, 94 and 95 5.0 and 94 3.8 Mustangs had either AODE's or AODE-W's (never heard of an AODE-W). 95 3.8 and 96 4.6 Mustangs had 4R70W's.
According to this diagram they're both wired the same (I say this because Mitchell only has one diagram for 95-96 Mustang trannies and mentions both in the diagram header):
AODE = close ratio 2.40 1st(same as AOD)... 4R70W Wide ratio, 2.84 1st...
Bad idea...  Idk anything about automatic transmissions but I do know that the 94/95 Mustang EEC system is horrible (and not swapable with 89-93 units - different wiring).  I think I read it was an attempt at better emissions but a bad one.  Appearntly even basic mods like intake or exhaust and suddenly youre fighting to get the car to run even halfway decent!
1988 Thunderbird Turbo Coupe
Quote from: booksix;161880
this is true! 94/95 mustang are EEC-V. you would need alot of wiring harness' to get it to work, or buy the $400+ Baumanator controller.
1979 Ford Fairmont
[/B]
another option is a full manual valvebody. i have this with a transbrake in my 4R70W. OD and lock-up will be on the same toggle switch.
1979 Ford Fairmont
[/B]
The 94/95 EECs aren't horrible. They just require someone who knows what they're doing to tune them properly.
