Topic: Has anybody had this problem before? (Read 1904 times) previous topic - next topic
Ok, I changed the Multi-Function Switch today on my car because the blinkers stopped working a while back and besides that I think it had an internal short because every time I hit the brakes, all the turn signal light would come on. I need to get a State Inspection sticker soon thats why I am doing this.
I changed it and I am still have the same problem, the blinkers wern't working, fortanatly I have the factory wiring diagrams for the car and knew what wire went where. I checked that I had power going to and coming out of the switch. Just for shiznits and giggles I moved the stalk on left blinker and the blinker lights came on, but didn't blink, I also noticed that I have feedback coming trough the brake lights, I have already replaced the flasher and that didn't fix it. Has any body run into this problem before, or knows a little more about this than an amature like me. Any help would be appreciated.
Re: Has anybody had this problem before?
Sounds like you may have a ground problem.
What do you mean by feedback in the brake lights? Are they staying on?
1986 bird, 306, Dart heads, 550 lift cam, exp. intake, 50lbs injectors, 76mm C&L MAF, Procharger D1R blower 14lbs, 3 core intercooler, 55shot ZEX N20, tremec 5speed, 3.73 gears, auburn pro posi,headman full length headers, 3" exhaust
custom chip by 5.8FastCat
[SIGPIC][/SIGPIC]1955 bird 351w, AFR 185 Heads, 580 lift cam, D1R  Procharger 10lbs tremec 5speed, 3.92 Gears
2007 Hayabusa, R-22 pipes, K&N,  Power Commander
192hp
"Imports are like tampons, every p@$$y has one"
Yeah, they are dimmly light I was think it was ground problem but that threw me off, the brake light that is.
Bad grounds can do some silly things...
Fixed, It was a ground problem, I looked at the book and found all the grounds related to that circuit, diconnected, cleaned and re-connected. Works fine now. Thanks guys for the help :)
