Topic: steering nightmare. (Read 1731 times) previous topic - next topic
steering nightmare.
Well, its one of those times where you hit somthing you felt would be inevitible... My pressure hose on the bird has leaked for eons.. and I replaced it. 2 months later its leaking again, so I poke my head under there to check it out and its lose as hell.. SOOO I undo the pressure hose only to find that I am stronger than I thought.... and i pulled the threads out of the rack :hick:  SOOOOO Im gonna be ordering a new rack probably tomorow, with all new goodies on it as tierod ends and all that fancy schmancy stuff. New struts and endlinks all that jazz.
Tell meh, on a scale of 1 to 10... how hard is it to swap a steering rack for a suspention dummy? I can do it... I just wanna know how hard it is...
-Clayton
steering nightmare.
Scale of 1 to 10.....I'd say a 3 or 4.Not really hard.Make sure you get a good alignment afterwards.I'd rather change it than a heater core,or oilpan gasket on a 5.0 Bird.
steering nightmare.
Fox rack swap = easy. It's right there and easy to get at.
steering nightmare.
sounds like a deal to me.
I ordered the new rack, tie rod ends, pressure side hose, swaybar endlinks, and shocks on all 4 corners.
steering nightmare.
If you're messing with the steering you might as well check the ball joints. Perfect time to replace 'em if they're bad:D
steering nightmare.
Yeah a steering rack on a Fox is pretty easy.  Now the rack on the Cavalier I changed.. GAWD...  Had to drop the engine cradle.
steering nightmare.
Get some Poly or Solid Bushings too if you can spring for them. I'd go with the solids and increase that Ackerman stuff. :D
steering nightmare.
Quick tip to save you some time: Hook up the hoses to the rack before putting the rack in place. You also might want to take some measurements off the old rack/tie rods to make it easier to drive to the alignment shop.
Jim
steering nightmare.
Quote from: thundr306;160204
Jim
Good advice. Tightening lines with an installed rack is a pain in the rear.
