Topic: patriot heads (Read 1115 times) previous topic - next topic
patriot heads
Cheap,anybody got experience with them?
patriot heads
I've heard that make good 2V and 4v mod heads so i would expect the same performance.
patriot heads
ive heard good stuff about their LSwhan stuff
patriot heads
Hey kitzdnm,
Just curious about your engine set up having E7's with 1.7 ratio rockers and E303 cam. Are you using the original SO block with the slightly dished pistons with no reliefs, or do you have valve reliefs in your pistons? I've got a set of E7's and 1.7 rockers but I'm reluctant to put them on my SO block with HO cam incase I get PTV interference. Engine-out-of-car type work just isn't possible for me right now. Thanks
87 Sport with HO cam, 19# injectors,TB+Upper Intake,87 Mustang EEC, Cloyes double roller timing chain, Kirban adj. fuel regulator and Autometer fuel pres. guage, HO shorty headers + LSC H-pipe and Dynomax Super Turbo lers, Ford Racing 9mm wires, K&N filter / no air resonator, 8.8 XR7 Diff., V rated tires, Project ongoing.
patriot heads
No I'm running a ho block.
patriot heads
Thanks, I might just go with a set of modified & ported E6's for the 1.7's on my SO block. Unless I come across someone with good experience with E7's and SO blocks.
patriot heads
By the way the E-7's aren't a problem with so.The E-303 + 1.7 more than likely will hit the pistons.I never tried it though.
