Topic: 7.5 brakes on an 8.8.... (Read 2178 times) previous topic - next topic
Can the 10 inch brakes (complete assembly) from my Thunderbird 7.5  be swapped onto my 8.8 Stang rear?i'm going to swap in my T-Bird axle shafts and brakes to keep my wheels where they need to be under my car.I wish I could find some 10.5 inch Cobra R wheels in 4 lug.With all of the stangs out there with 4 lug wheels,and all of the Cobra R wheels sold,you'd think that the wheel makers would produce them (small rant,it's over now)..
Sorry Vinnie...as this has been covered ALOT.
You have the wider 7.5 housing (86-88).  You could swap your brakes over to the Mustang housing and use the Mustang axles, but your axles will not work in the narrower 8.8 housing.  If you had the narrower 7.5 housing (83-85), then things would swap over w/o issue.
Your doing kinda what I am, only using a newer axle.
II may have a narrower TC rear (drum brake) in the garage.I know it's older as it has the 3.45 gears.I was hoping to keep from using spacers.I'll go do some measuring.I'll just use the T-Bird axles and 9 inch brakes then if the older rear is the same width as the Stang rear.
When I put in a mustang 8.8 into my 87 cougar, I used my 10in cougar brakes with the mustang axles. This was a simple bolt on replacement of the mustang 9in brakes. Hope this helps.
Our web page
02 Explorer XLT 4.0L
04 F150 FX4 Supercrew 5.4L
02 Saturn SL1 1.9L
09 Vstar 950 Tourer
Quote from: 1badcougar;159688
Yes, and you also pulled the rear wheels in 3/4" per side in doing so.
The Stang rear has 10 inch brakes,as does the T-Bird rear I have now in the Sport.BUT,the 7.5 TC rear has 9 inch brakes,so,I'll just go 9 inch brakes and axles and call it a day.The difference between 9 and 10 inch brakes is probably just about nothing.
Think about it vinnie, thats an whole extra inch of braking. Do the math and it will supprise you. If you can do it, I vote kick ass on it. If you can't then just do 9"
Yes,it's an extra bit of brakes,but,considering that most of the braking is on the front,I really doubt I'd be able to tell a difference.I'd leave the stang rear alone if some wheel company would make 10.5 Cobra R wheels in 4 lug.
I'm confused? about the 7.5 tc rear?
Quote from: kitzdnm;159747
83-86TCs had a 7.5 rear axle with 3.45 gears.
The 83-85's had the "narrow" Mustang housing and the 86's had the wider housing.  All were the same track width (axle  to axle )
Geez,even I knew that.................after Chuck told me 68 times.LOL.
About what? Only the 87-88 TCs came with 8.8s.
EDIT:
Dadgummit! That's what I get for not clicking the post button. :(
I will always be confused.But I do build them right.
