Topic: '86 vs 88 front springs... (Read 1873 times) previous topic - next topic
What is the actual difference in the '86 and '88 front springs? Will they interchange?
I'm pretty sure all years ('83-'88) of springs will interchange.
If anything, I would think there would be a different rate for springs depending on if you use V6 springs from the 86 insted of th e 88 V8 springs. But will they phisicaly interchange I'm with Brian, yes
The spring rates will be different depending mostly on the weight of the engine and since the earlier cars weigh a little less, they are probably slightly different... I still have the original 4cyl springs in my TC and it now sets approx 3/4" lower than stock...
BTW the rear are generally the same... The 5.0 Sport I junked had the same springs as most TCs... My car has different spring codes(front and rear), than most TCs Ive seen, what the differences are I dunno...
Thanks guys. I thought I remembered reading there was a difference in the springs but I guess I was wrong. Just ordered a set of Koni Sport springs off ebay.
