Topic: fuel line ranting (Read 912 times) previous topic - next topic
fuel line ranting
Ok so i bought a set of the plastic disconnect tools, cause i was to broke from the metal ones. Once i figured out how they go on the lines i press up spring moves, and lines still wont budge? is there some trick to these  things? under there is so greasey its not even funny, and theres coolent on everything so i know the waterpump is gone..... someone help me before i freak out!
fuel line ranting
patience, young jedi.
pull/push to get the lines off, once the tool is seated properly.
1979 Ford Fairmont
[/B]
fuel line ranting
i got a tip to twist them it worked perfectly!
fuel line ranting
Dirty lines?I thought I told you to clean everything up first.Impatient youngsters.
fuel line ranting
this  fuel line  is so gay.
thunderbird lines are wayyyyy off, and stupid ass pepboys guy gave me a compression union for a low presure system, talked to my dad he told me i need flared fittings, and i need to double flare them. not even sure i can get them to mate together. God i wish i knew what i was doing!
fuel line ranting
ok so they are not that bad now that they are secured in there, only i dont know which line goes to which one..... the line with the big quick disconnect would be the feed line and the small disconnect would be the return line right???
