Topic: Oil mist coming out of dipstick Advice needed (Read 970 times) previous topic - next topic
I recently swapped another 2.3 engine because I had some problems with my last engine. I am having oil mist coming out of my dipstick while in park and reeving the engine. If under load more comes out I am not running a pcv valve just a breather. What could I do to fix this problem Im currently just running the turbo but with the supercharger oil mist comes out alot more also in idle. What can fix my problem any ideas? thanks
87 T-Bird turbo'd and supercharged and if things call for it juiced. :evilgrin:
88 Turbocoupe t3, 4.10's, Daily driver
What do you have on the crankcase breather?  Are you running a breather on the v/c too?
It's obviously blow-by, but it could be aggravated by lack of crankcase ventilation.
On the crankcase im just running a breather and also on the vc to a catch can what else could I do to help solve my problem?
PVC system or a good electric vaccume pump
