Topic: Shifter install (Read 1148 times) previous topic - next topic
Shifter install
The temp plate in the tech section,What does it mean it's plus size? It looks to small after I printed it. I'm cuttin the hole tonight. Does anyone know the measurment front to back on the temp.side to side would help to.
Shifter install
The hole really isn't very big for the shifter to go through.Probably better to cut a little small and work your way up.I did the floor shifter conversion on old Blue about 8 years ago.The Sport already had one.I also added the tranny tunnel hump that the shifter bolts to,that way,the shifter sits right in the console.No promises,but I may be able to take that piece from the Blue Bird for you if you don't already have one.I don't know if it will come out easily,but I can try.If I can,I'll let you know.
Shifter install
Not plus size (that's for tires and chunky ladies), plus shaped, like the + on your keyboard. It's the shape of the hole you need to cut.
The whole shifter doesn't go through, just the pointy-downy parts. The rest sits on top.
Ooooo, we got measurements! Here's a picture of the flat-topped plate that is glued+screwed to the tunnel in regular floor-shift cars, still attached to a chunk of the tunnel (pic is upside-down, dash is at the bottom), followed by the measurements I just took of the hole. Good enough?
Shifter install
That will work more than work thanks Masterblaster,I got side tracked pulling hedge fences so it didn't get cut,This weekend it's going in.
