Topic: Some pics of my junk (Read 3682 times) previous topic - next topic
I recently installed manual brakes, Strange 33 spline spool and axles w/ c-clip eliminators, 4.56 gears, Lakewood rear shocks, rear springs - 1-7/8 coils, front 4 cyl springs - 1 coil, M/T 275/60-15 DR's, swapped T5, and a PIP to get it going again.
Anyway, I put some pics in photobucket and thought I would share.  What do you think?
http://s196.photobucket.com/albums/aa216/Sluggo_2007/
wow that engine set up is sweet!!!! looks good man!
How are the manual brakes working? The master cylinder is from a mustang right? How is the pedal feel?  Car looks real nice good job!!
87 T-Bird turbo'd and supercharged and if things call for it juiced. :evilgrin:
88 Turbocoupe t3, 4.10's, Daily driver
Thank you.
The brakes work very well.  They do require more effort and the pedal feel is what you would expect,  more effort = more braking,  very consistent.  The m/c is a 80 Mustang manual unit and I put a Summit adjustable proportioning valve in place of the stock one.
, I never realized how empty a spool leaves your diff housing.  That must be interesting going around hard turns.  And forgive me for sounding stupid, but it does look like there's an additional mounting hole for the rear lower control arm.
I was thinking of doing manual brakes. You say they feel good and work well. Now is this on the streeet or on the track? I will be using mine on the street is why I ask
Looks bitchen.
1987 Cougar XR7 5.0 SOLD
1992 Ranger 4.0
2018 Hyundai Elantra
2019 Ram Rebel
Sweet :birdsmily:
Thanks again for the kind words.
Ifixyawata, There are 3 mounting holes for the LCA's now.  I drilled one in the center of the 2 you see.  You can read more about it here.
http://www.foxtbirdcougarforums.com/showthread.php?t=13603
Fila,  So far I've only been on the street.  I feel confident in them for street driving, but you have to remember they are manual and apply foot pressure accordingly.  There is no way I could lock the tires up with all my 170#s and in other than emergency braking they stop in the same distance as you would comfortably with power assisted.  Also, I don't reach for the pedal any sooner than I normally would.
Sounds good bro. You may have sold me on manual brakes
You need to be sold on getting the car legal before you mod it more
Waiting on word back from the laywer. I have to get it running again vefore I need brakes while I'm at it.
lawyer?
She ( PO's wife) Told me it had to go to probate? court. I'm calling her later.
