Topic: Liquidation Sale (Closed for Vacation) (Read 4649 times) previous topic - next topic
***UPDATE***
I am going on vacation August 12th to the 20th. I will have limited internet access and very limited access to parts. Therefore I will not be selling any parts until August 21th.
Serious replies only!!!
Everything must go! It's time to move on.
If you need pics let me know and I will post them ASAP. I will be updating this list as the parts become available. If you know of something specific you want feel free to ask.
First Come First Serve.
//Engine Related
Race Engineering Adj. Cam Gear - $old!
  • Less than 20 Miles on it.
BPV Kit (Everything needed to install a BPV on your 87-88TC) - $old!
  • Stock TC Intercooler with 90* Elbow for BPV.
  • Forge BPV
  • Misc Hoses, Couplers, Clamps
Big VAM w/unknown Air Filter - $old!
Gillis Boost Controller - $old!
(4) 35# Injectors "Brown Tops" - $Sold!
  • Recently flow tested.
Kirban AFR w/Gauge - $old!
  • Very low miles on it.
MaxPSI Oil Feed Line - $old!
Dizzy w/ Fairly new PIP/TFI/Cap/Rotor/Wires - $old!
TFI Relocation Kit - $old!
T-3 (.60/.48) Turbo - $old!
  • Spools great!
  • Compressor Housing modified for top mount intercooler
  • Comes with Oil Return Line
  • Adjustable WGA and Bracket.
  • [/SIZE]
  • O2 Sensor Included
Stinger 3-Inch Downpipe - $old!
Stinger 3-Inch Exhaust - $250 + Shipping
  • From the Downpipe Back
  • Magnaflow ler
  • Exits Passenger Side
  • Tailpipe Painted Black
  • Will need to be CUT to ship!
Ported E6 Manifold - $old!
  • Cracked in three places!
//Electrical
Alert Car Alarm for 87-88 TC w/Manual Transmission (NIB) - $old!
  • Remote Start
  • Turbo Timer
  • Keyless Entry
H3 55w Fog Light Bulbs (NIB) - $15 Shipped
Headlights w/ Ultra Blue Bulbs - $old!
  • Look new no yellowing.
3G Alternator - $old!
2.3 Mini Starter - $old!
  • Includes Wiring.
Suspension
*Due to the relocation of the vehicle for removal of suspension parts or any parts remaining on the vehicle, there will be a delay in shipping, pictures and a general availability of parts. I apologize for the inconvenience.
MM Caster/Camber Plates - $old!
  • Get your handling on!
FRPP Springs (Tbird/Cougar Specific) - $old!
  • M-5300-D
Prothane Endlinks & Swaybar Bushings - $old!
FRPP 2003 Cobra Control Arms - $old!
  • Same length as 87-88 Thundercats
  • Perfect fit when using SN-95 Front Brakes.
  • Low miles.
  • M-3075-D
Tokico Struts & Shocks - $old!
  • Used on Mustang Bullitts
Flaming River Steering Shaft - $old!
  • Has some surface rust.
HPM MegaBite Jr. Control Arms - $225 Shipped
  • Comes with ChuckW Shock Brackets. (Modified to use with arms)
  • Thundercat Specific Arms.
  • [/SIZE]
TC Rear Parking Brake Cables - $old!
  • Very nice!
  • [/SIZE]
Front 5-Lug Conversion - $old!
  • PBR Dual Piston Calipers
  • Classic Tube S/S Braided Lines
  • New(ish) Pads, Rotors, Hubs
  • 96-98 SN-95 Spindles
KB Subframe Connectors - $old!
8.8 Rear End - $200 + Pickup
  • 96-98 SN-95 Axles/Calipers/Rotors/Pads (Complete 5-Lug Disc)
  • [/SIZE]
  • 3.55 Gears
  • Eibach 1-Inch Spacers
  • Classic Tube S/S Brake Lines
  • TrickFlow Girdle will be removed, and stock cover reinstalled
  • [/SIZE]
//Tranny
MGW Shifter - $160 + Shipping
  • Includes Leather FRPP , MGW Boot and TC Inner Boot.
  • [/SIZE]
//Exterior
2.3 Badges - $old!
//Interior
White Face Indiglo TC Instrument Cluster - $old!
  • Smudge on gas gauge. (Should of washed my hands.)
  • [/SIZE]
A-Pillar Dual Gauge Pod - $old!
  • Comes with Boost/Vac Gauge & Narrowband A/F Gauge
  • Gauges are 2-1/16"
  • Boost Gauge DOES NOT Light Up!
Halo Headrests - $old!
Much more to come!
Awaiting Relocation to Remove the Following
SN-95 Front & Rear Brakes
...more
Details/Contact Info
I am located in Royal Oak, MI 48073. The best way to contact me is in this thread or by email: ether947@gmail.com
I accept paypal ONLY unless you are a senior member of this board, in which case I will consider other methods of payment.
- Listed on eBay. Will Not cancel auction until transaction is completed.
* - Due to the relocation of the vehicle for removal of suspension parts or any parts remaining on the vehicle, there will be a delay in shipping, pictures and a general availability of parts. I apologize for the inconvenience.
Moving on?  That sounds ominous. :(
Indeed it does. Surely Darkthunder isn't going anywhere?
i take it its getting parted cause its no longer mentioned in your sig...
Interested in the cam gear ill see what kind of cash i can rustle up.
Quote from: Thunder Chicken;158038
No, just this 87TC. I'd keep some of this stuff for darkthunder but I need to buy another car ASAP.
Oil Feed and Dizzy may be spoken for.
Gillis is sold!
whats going on with the exhaust? i will let me dad know if you are looking to get rid of it for cheap.
Quote from: daboss351;158145
Its going, but not for "cheap".
well i meant lower then new, what you looking to get for it
Quote from: daboss351;158195
Not sure yet. Probably in the mid-to-low 300s.
ill tell him
pm sent
you got pm
PMs returned.
