Topic: Birds new rear and HOOD new pics page 3 (Read 10611 times) previous topic - next topic
Well fella's I swapped out my 4.10 geared factory  rear today for the one from my stang.I tried to get measurments of everything just so we have a record of the lenths.
ill try to describe each pic
old rear is shown out of the car here
:hick:
the donor rear
31 spline strange axles
5/8th studs
3.73 gear and full spool
moser girdle
C clip eliminators
and of course the southsides,lakewods,and solid uppers
stock upper and aftermarket mustang upper
now the lowers i measured these from center to center on the holes just as the top ones.
now the overall width these should be pretty close its hard to measure and take pics all by yourself.
now shock length
stock vs lakewoods at full extension
and a few on the ground
Im nto real happy with the ride height so far i plan on changing springs
I stuck with the mustang a control arms to try to change the wheel base and create more rear overhang to see what it does to effect traction if i cannot see a great gain i will lengthen them as needed to correct the wheelbase.
Keepin' the drums on there?
Quote from: DakotaEpic;157987
yeah there a little lighter
a few more
looks good, will be sweet once you lengthen the bars!
thanks
Is that a black notch stang in the backround of the first pic?
thats his stang the one the rear end came from, the one that the hood poped up on
