Topic: Brake booster or master cylinder? (Read 1179 times) previous topic - next topic
Before the heads decided to let loose, the brakes started getting funky, it was all around when I started getting alot of compression in the radiator.
I have like 2 inches of pedal travel, that's if I stand on the pedal AND I'm a big kid.
She does stop and no the pedal doesn't fade.
Is it possible that the warped heads would cause the amount of vaccuum the engine pulls to be so low that the brakes become piss poor? (Fila's phrase = piss poor):hick:
Thanks all
I said it could be. I didn't have my Vac lines done right and when correced it got better. But I still have a bad booster so that may play into yours as well. Fix it first at the heads and go step by step
